5248 Diskussionen
BMC RMM4 connection failure
TNils5
Einsteiger
1.689Aufrufe
I have a set of S2600JF with RMM4. BMC firmware BMC FW Rev : 01.16.4010.
I set it up but cannot connect to it (even if I attach a standalone PC to the NIC management port). When I connect it to the Switch, I see some ARP MAC addresses. I suspect the MAC address is not from the RMM4 but from a Baseboard MAC.
Can you propose any solution or troubleshooting guidance?
Tore
2 Antworten
SergioS_Intel
1.537Aufrufe
Hello TNils5,
The interactive technical support for the Intel® Server Board S2600JF you have requested has been discontinued. We can provide you with resources and self-service support information through our website.
 https://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/g31608015_s2600jf_tps_r2_41.pdf
We highly suggest that you get information from the technical product specification site and all available technical information is included in the support site.
You can additionally check how to configure the Baseboard Management Controller (BMC).
https://www.intel.com/content/www/us/en/support/articles/000007913/server-products.html
I am going to proceed and move your thread to the Discontinued Products Community, so you can get recommendations from fellow community members.
Sergio S.
A Contingent Worker at Intel
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
Max44
Einsteiger
1.537Aufrufe
Here’s our piece of code using RRM:
public static void Get()
           var wsman = new WSManClass();
           var options = (IWSManConnectionOptions) wsman.CreateConnectionOptions();
           if (options != null)
               try
                   options.UserName = "root";
                   options.Password = "root";
                   int iFlags = wsman.SessionFlagCredUsernamePassword();
                   var session =
                       (IWSManSession) wsman.CreateSession("http://10.182.171.195:8889/wsman", iFlags, options);
                   if (session != null)
                       try
                           var identity = session.Identify();
                           var s = "http://schemas.dmtf.org/wbem/wscim/1/cim-schema/2/ComputerSystem";
                           var reply = session.Get(s);
                           var doc = new XmlDocument();
                           doc.LoadXml(reply);
                           foreach (var elementName in new string[] {"p:Caption", "p:Description"})
                               var node = doc.GetElementsByTagName(elementName)[0];
                               if (node != null) Console.WriteLine(node.InnerText);
                       finally
                           Marshal.ReleaseComObject(session);
               catch (Exception ex)
                   Console.WriteLine(ex);
               finally
                   Marshal.ReleaseComObject(options);
Antworten
