5216 Discussions
Cannot enable I/OAT with 82576 on Windows Server 2008 R2
GBonn1
I have a motherboard (Supermicro) with Intel 5520 Chipset+ICH10 with dual socket configuration populated with 2 Xeon 5670. The motherboard design has the Intel 82576 network chip. I installed Windows 2008 R2 and proceeded to install the network driver using the latest driver available on Intel site. When I use the IOATCHK utility provided on the Network Connection CD the utility complains that the hardware doesn't support I/OAT. Yet my understanding is that it should.
What wrong?
Daniel_O_Intel
From http://downloadmirror.intel.com/12193/eng/readme.txt
Intel I/OAT requires the following to operate on Microsoft Windows
Operating Systems:
- A server chipset and BIOS that are Intel I/OAT capable
- An adapter or network connection that is Intel I/OAT-capable
- The RSS advanced setting must be enabled
- Under TCP/IP Offloading Options, both Offload Receive IP Checksum and
Offload Receive TCP Checksum must be enabled.
I'd double-check the BIOS on the board, make sure it's enabled, and make sure you've altered the two NIC settings.
GBonn1
I had already checked this list before asking. But I did double check again to make sure I didn't forget anything. I meet all these requirement. The BIOS does have the IOAT setting to enable.
Yet the IOATCHK utility does say that the hardware doesn't support IOAT.
However using the command:
netsh int tcp show global
I got this report :
C:\Users\Administrator>netsh int tcp show global
Querying active state...
TCP Global Parameters
Receive-Side Scaling State : enabled
Chimney Offload State : automatic
NetDMA State : enabled
Direct Cache Acess (DCA) : disabled
Receive Window Auto-Tuning Level : normal
Add-On Congestion Control Provider : ctcp
ECN Capability : disabled
RFC 1323 Timestamps : disabled
The DCA is disabled but the BIOS has the DCA set to enable. Could this be the problem ?
Here there another means beside IOATCHK to check if IOAT is enables?
