5224 Discussions
Cannot update s3420gplx firmware
Hello experts,
I have a s3420gplx server board with biod version 22.
i want to update it to the latest version -- 42, but i keep getting the folowing message:
Update file configuration: XXX S3420GPX:S3420GPV:S3420GPC,1.0ERROR: Current BIOS is not compatible to be updated to this package!
I've allready run the System Id tool, the referente number is 0018 7931 -- if you can use it to verify versions.
i've allready tried to update the firmware using that package.
i've allready read the release notes....
I am trying to update it using OFU and keep getting that error.
Initially i had the MS ipmi driver but i've allready tried installing the Intel ipmi driver (from sysinfo) bvut got the same error.
I haven't tried to update it using EFI yet.
JasonT_Intel
Did you get any luck with the EFI updates ?
