Determine error on Intel server
Hi guys,
We have an old Intel server which is still doing all right with Windows 2003. I noticed that the health indicator is "orange" color, which I suppose is bacause something is wrong. I removed the side, and I see some red lights on some of the extension cards. But I don't know what it is and what the error is, I don't even know which kind of server it is.
There is a software called ISM Console installed on the server, and I can see a red/white cross in health status, but the program asks for a password to see the error which I do not have.... How can I reset this ?
Edward_Z_Intel
Try to locate a white label on the mainboard, which has a serial number and a part number in ABCDEF-123 format. Those will help to identify the server.
JasonT_Intel
There is no way to reset the password for the server management console. Typically when I install the management console, I would use the same Windows password. Have it a try, it may work.
Also, you can use a system event log utility to check for the actual error on your server. As I do not know which server you are using, there are different versions depending on the platform.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17933&lang=eng SEL Viewer for UEFI/Windows*/Linux* for S5500 and S5520 boards
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18871&lang=eng SEL Viewer for Windows* and Linux* for S5000 boards
