5295 Discussions
Does S1200SPLR support 7th Core i3 processors, and ECC UDIMM?
晨李2
Hello.
There are 3 questions.
Q1. Does S1200SPLR support 7th Core i3 processors?
Since the ARK website shows that yes, but the TPS pdf document only talked about the Xeon E3-1200 v5/v6 and 6th Core i3 processors.
https://ark.intel.com/products/97950/Intel-Server-Board-S1200SPLR
https://www.intel.com/content/dam/support/us/en/documents/server-products/S1200SP_TPS_AllSKU.PDF
Q2. Does 7th Core i3 processors support Unbuffed ECC memory?
At the first launch of 7th Core i3, the ARK website said NO about ECC memory support. Even now, some of OEM vendor, like Lenovo, still said NO ECC memory support.
https://lenovopress.com/lp0600-system-x3250-m6-intel-xeon-e3-1200-v5-v6-core-i3-pentium-celeron-g-series#processors
But at this time, the ARK website shows YES.
Q3. Is it possible to build a server which together with S1200SPLR, Core-i3-7300 and DDR4 ECC UDIMMs?
And make it full functional.
BTW
When will Intel release next generation entry level server board which support Coffee Lake family CPUs?
Or NEVER?
Jeremias_A_Intel
Hello Michael, I apologize for the delay in the response to your questions. Please see below answers: Q1. Does S1200SPLR support 7th Core i3 processors? Since the ARK website shows that yes, but the TPS pdf document only talked about the Xeon E3-1200 v5/v6 and 6th Core i3 processors. https://ark.intel.com/products/97950/Intel-Server-Board-S1200SPLR https://www.intel.com/content/dam/support/us/en/documents/server-products/S1200SP_TPS_AllSKU.PDF ---The S1200SPLR does support 7th Generation processor. Noticed that in the Technical Product Specification the SPLR (which is a refresh version) is not showing. Make sure the S1200SPLR you are using has the latest BIOS. Q2. Does 7th Core i3 processors support Unbuffed ECC memory? At the first launch of 7th Core i3, the ARK website said NO about ECC memory support. Even now, some of OEM vendor, like Lenovo, still said NO ECC memory support. https://lenovopress.com/lp0600-system-x3250-m6-intel-xeon-e3-1200-v5-v6-core-i3-pentium-celeron-g-series#processors But at this time, the ARK website shows YES. ---- Can you please speciy the 7th Generation i3 CPU you are planning to use? as there some 7th Generation i3 that does not support ECC memory Q3. Is it possible to build a server which together with S1200SPLR, Core-i3-7300 and DDR4 ECC UDIMMs? and make it full functional. Yes, it is possible. Integrated Memory Controller (IMC) and Memory Subsystem https://www.intel.com/content/dam/support/us/en/documents/server-products/S1200SP_TPS_AllSKU.PDF BTW ---When will Intel release next generation entry level server board which support Coffee Lake family CPUs? Or NEVER? There is not estimate time at the moment. If you have more questions, do not hesitate in contact us again Regards, Jeremiah Allen. Technical Support Representative, Server Specialist, Server Products Support Under contract to Intel
Jeremias_A_Intel
Thank you for contacting Intel Technical Support.
We investigate on your questions and get back to you as soon as possible with new information.
Your patience is highly appreciated.
Jeremiah Allen.
Jeremias_A_Intel
晨李2
Hello Jeremiah
Thanks for reply! It helps a lot. About Q2, I mean i3-7100 or i3-7300.
Although S1200BTLR is good for me, but I still want a new platform. Can you tell me whether Intel is working the new motherboard or not?
Jeremias_A_Intel
Hello Michael, At the moment, there is no confirmation from Intel about this. My suggestion is for you to keep checking Intel's site and forums for new updates. If you have any question, please let me know. Regards, Jeremiah Allen. Technical Support Representative, Server Specialist, Server Products Support Under contract to Intel
