Intel® Xeon® Processors, Data Center Products including boards, integrated systems, and RAID Storage
FH82C266 - Help
OneExplorer
Hello Intel team,
I am currently working on a development project using the Intel® C266 Platform Controller Hub. I am trying to source the chip FH82C266 with the Spec Code SRM8L, which is referenced in the official documentation.
However, most distributors I contact are offering FH82C266 marked as Q1LH instead of SRM8L. I could not find official information explaining this Spec Code.
Could you please clarify:
What does the Spec Code Q1LH signify?
Is FH82C266 Q1LH equivalent to SRM8L in terms of features and compatibility?
Are there any restrictions or differences we should be aware of when sourcing Q1LH?
Your guidance would be highly appreciated, as we need to ensure correct part selection for our project.
VishalS_Intel
Hello OneExplorer,
Greetings!!
Thank you for contacting us.
To proceed further, we kindly request you to check with an Intel genuine distributor for accurate information and proper assistance regarding your concern. They will be able to validate the product details and guide you with the next steps accordingly.
Please check the below link for your reference-
https://www.intel.com/content/www/us/en/partner/showcase/partner-directory/distributor.html#sort=relevancy
Please feel free to reach out if you need any additional support from our side.
Vishal Shet P
