Intel® Xeon® Processors, Data Center Products including boards, integrated systems, and RAID Storage
5241 Discussions
How can I read the DDR5 R-DRAM voltage values and SPD contents?
Devin_Chang
Hi ,
Our company is a DRAM manufacturer, and during product development, we need to read the R-DRAM voltage. We would like to understand your CPU's SMBus configuration and control method. Could you provide a simple process or sample code for this?
I am using EDK2 code to develop a testing program in the UEFI environment.
CPU : Intel(R) Xeon(R) W5-3435X
MB : ASUS Pro WS W790-ACE
Devin
MACM
Hi Devin_Chang
Greetings from Intel.
Hope you are doing well.
Could you please let us know if the processor was purchased separately or its embedded.
So that we can proceed further accordingly.
Mohammed Ali CM
Devin_Chang
Hi  Mohammed Ali CM,
Thank you for your reply.
My processor was purchased separately and paired with the ASUS Pro WS W790-ACE platform.
Devin
Ragulan_Intel
Hi Devin,
Greetings!
You may refer to the links below that would provide an insight on your query. If there is any other concern, do let us know.
Thank You and Best Regards,
Ragulan_Intel
Devin_Chang
Hi Ragulan,
Thank you for providing the related documents.
I have a 2024 document here, and the SMBus configuration in it shows completely different register addresses (Bus:Device:function) compared to the 2021 document you provided.
Please confirm which one I should use.
612246_SPR_EDS-R_Rev_2_4.pdf
4th Gen Intel® Xeon® Processor
Scalable Family, Codename Sapphire
Rapids
Registers Specification
Rev. 2.4
May 2024
Intel Confidential
Could you also provide a simple code example or configuration process?
Devin
vish1
Hello Devin_Chang,
Greetings!!
I wanted to confirm that Document ID 612246 is indeed the correct document regarding your inquiry about the SPR. However, I regret to inform you that we are unable to provide a code example at this time.
For further assistance, I recommend reaching out to your Intel Representative, who can offer the support you need.
Thank you for your understanding, and please let me know if you have any other questions.
Vishal Shet P
Poojitha
Hi Devin,
Greetings for the day!
Thank you for your response. We kindly request some time to check the details and provide you with an update.
We appreciate your understanding!
Poojitha
MACM
HI Devin_Chang
We request you to please reach out to intel embedded community for more information. Below is the link.
https://community.intel.com/t5/Embedded-Products/ct-p/embedded-products
Ali
