Install Issues
I have a s5000Vsa mult-core Xeon Processor motherboard. When I try to reinstall SBS R2 I keep getting an error that states could not find hard drives. I do believe I need to install the correct Raid driver but I'm not sure which to use. Any help would be greatly appreciated.
Edward_Z_Intel
It depends on which SKU you're using, and how you configured your storage options in BIOS. Try this tool to help you to identify the driver you need: http://www.intel.com/support/motherboards/server/sb/CS-030283.htm http://www.intel.com/support/motherboards/server/sb/CS-030283.htm
Thanks for your help. That did the trick. I downloaded the correct driver.
