Intel Chipset C252
Norion
We are presenting an issue with the C252 Chipset and the Kingston SSD brand specifically with the models: SA400S37/120G and  SA400S37/240G.
When trying to make Raid 0, 1 always the raid is degraded. It was done with other SSD models and other brands and it worked. The tests were performed with Gigabyte MX33-BS0 and Asus P12R-M motherboards.
Any suggestion?
JosueO_Intel
Hello Norion,
Thank you for posting on the Intel communities. In order to have a better understanding of the issue, please share with us the following information:
  1. Does the issue occur if you try a different RAID level?
  2. Have you checked the compatibility between the drives and the motherboard?
  3. Brand and model of the other drives being tested.
Josue O.
SergioS_Intel
Hello Norion,
We are following your thread and would like to know if you need further assistance.
Sergio S.
SergioS_Intel
Hello Norion,
Sergio S.
JosueO_Intel
Hello Norion,
Josue O.
