Intel MFSYS25 Fans
We have an Intel MFSYS25 Chassis which over the past few days has seems to have increased it's fan speeds (and noise) even though the room temperature has stayed the same and the usage is no higher. Looking at the dashboard and error logs no problems are reported.
Is this a known issue?
Lee
Daniel_O_Intel
No known issue with the fan speeds increasing. What RPM are they running at now, and what were they running at a few days ago?
Dan_O,
Thanks for your reply.
The Upper Rear System Fan states the following: -
Temp - 28 degrees C
Tachometer # 1 - 2600 RPM
Tachometer # 2 - 2700 RPM
The Lower Rear System Fan states the following: -
Temp - 22 degrees C
Tachometer # 1 - 2700 RPM
Lee
