Intel Modular Server Array
Sorry but i vent find a correct answer ....
Hi ,
I ve a question of storage . I ve got a pools with 5 disk 300Gb sas with 1 spare . I ve buy 8 disk 600Gb sas . I ve alredy add to pools(with expand pools) . But pools seems see a 300Gb disk . There is a solution for revert expansion or for see all space ?????
Thanks a lotS
Daniel_O_Intel
Did you put the 600GB drives into the same virtual drives as one of the 300s?
You can have drives of different size in the same storage pool, although it is not recommended. If you can, create a second storage pool to put the 600GB drives in.
