Intel Server board S2600CW2SR
RPads
初学者
2,776 次查看
I have made a server setup with 2 xeon e5 2620-v4 processor.
my pc starts but stuck at boot. USB ports are not working as keyboard and mouse are not working. screen stuck at
"Warning: This server is running factory firmware.
A software update is required.
Please load the latest system update package(SUP)
to unable the latest security, quality and performance capabilities.
0 项奖励
9 回复数
员工
1,624 次查看
Hello ravindrao5 ,
Can you perform the following steps in order to update the BIOS?
  1. Download the latest firmware for Extensible Firmware Interface* (EFI*) from the support site.
  2. Unzip the package and copy all files to a folder on a USB device.
  3. Insert the USB device to the server/workstation USB port.
  4. Boot the server to the EFI shell.
  5. Run the map -r command in EFI shell to map USB device.
  6. Run the fs0: command to change folder to USB device. USB device can also map to fs1:. The number of the fs# is dependent on the result of the map -r command.
  7. Change the folder to the folder storing the firmware package.
  8. Run the startup.nsh command to start updating all the firmware and BIOS.
You can download the software by accessing this link:
https://downloadcenter.intel.com/download/28004/?product=88276
Charlie_Intel
0 项奖励
员工
1,624 次查看
Hello ravindrao5,
We are wondering if you were able to perform the troubleshooting steps?
Charlie_Intel
0 项奖励
员工
1,624 次查看
Hello ravindrao5,
We are wondering if you need further assistance?
Charlie_Intel
0 项奖励
RPads
初学者
1,624 次查看
Does this mother board supports non ecc ram?
0 项奖励
员工
1,624 次查看
Hello ravindrao5,
This board only compatible with ECC memory.
Charlie_Intel
0 项奖励
员工
1,624 次查看
Hello ravindrao5,
Charlie_Intel
0 项奖励
员工
1,624 次查看
Hello ravindrao5,
We are wondering if you have further questions?
Charlie_Intel
0 项奖励
RPads
初学者
1,624 次查看
No, Thanks..
0 项奖励
员工
1,624 次查看
Hello ravindrao5,
You are welcome if you have further questions do not hesitate to contact us back.
Charlie_Intel
0 项奖励
回复
