5230 Discussions
Intel adapter teaming Config problem with WMI
I have a problem with teaming configurationn of Intel Pro/1000 PT QUad port LP server adapter.
I am able to create the teaming using the script under the C:\Program Files\Intel\NCS2\Scripts\
However,Each time After the system idle for about 10min,
The script no longer able to query the teaming information and i need to reboot the server to make it work again.
I am wondering it is the WMI provider problem
Is there any idea on how to resolve this problem?
I am using the installer PROEM64T.exe v 4.0.100.1124
Alan Jim
Daniel_O_Intel
Once the team is created, the script shouldn't need to continually query. If you create the team through the OS, is it stable? Are you using XP or 2003?
