5328 Discussions
Is the Intel Integrated RAID Module RMS25JB040 compatible the HGST Ultrastar A7K2000 HUA722010CLA630 ?
Good day!
The HUA722010CLA630 (6Gb/s) is absent at this list http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/rms25kb0x0_rms25jb0x0_thol_v31.pdf http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/rms25kb0x0_rms25jb0x0_thol_v31.pdf (Revision 3.1 November, 2013). The HUA722010CLA330 (3Gb/s) tested only.
Please let us know the model number for the server board you are looking to use for this RAID controller.
Intel Server Board S1200V3RPL (C226)
HGST Ultrastar A7K2000 HUA722010CLA630 1Тб
After checking the specifications for the drive, it should work fine but the part number has not been confirmed as validated hardware from our side. The validated hardware can be found here:
https://serverconfigurator.intel.com/exalt/RequestManager?ServletNumber=1&localinfo=0&RestrictionVal=SVG&APPLICATIONCODE=1 Serverconfigurator.intel.com
