5328 Discussions
Local Control Panel compatability(reuse)
DRhod
I have a SV-AS Intel Local ControlPanel (AXXLCPRACK, version C73060-001). I was curious how to use in other systems. I have found documentation that gives the pinouts of the 50-pin connector, and the 10-pin USB header. But what would I need to hook up to if it is not going in a Dell? Can I get there from here? Or just toss it?
I hope to combine this with a new Asus (server) board. Like the Z10PE-D16. If it helps.
Any help is very much appreciated. Thank you
Documentation I found:
LCP Technical Product Specification: http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/c96442003_lcp_tps_r1_2.pdf http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/c96442003_lcp_tps_r1_2.pdf
Firmware: https://downloadcenter.intel.com/download/10870/Intel-Local-Control-Panel-Firmware-Update-for-DOS?product=4782 Download Intel® Local Control Panel Firmware Update for DOS and https://downloadcenter.intel.com/download/13331/Intel-Local-Control-Panel-Screen-Menu-Update-Utility-for-DOS-?product=4782 Download Intel® Local Control Panel Screen Menu Update Utility for DOS
Also, though not a huge deal, I cannot seem to find the Intel® Local Control Panel Customization Kit utility (ILCPCK.EXE) or Intel FWPIAUPD.EXE firmware update utility.
To answer your question, the Local Control Panel AXXLCPRACK is a discontinued product and has been tested on the following Intel server systems only:
Intel® Server System SR1500ALR
Intel® Server System SR1550ALR
DRhod
Thank you very much for the reply. But it does not really answer the question. I am more looking for how I would be able to connect and use the unit in another computer. I have already found that this is an old unit, hence me wanting to use it elsewhere. Is all of what is needed to use it so proprietary that I will not be able to use it?
To answer your question the unit is proprietary of Intel reason why it will only work on the Intel servers systems mentioned before. The component is not compatible with third parties. Thank you for your understanding.
