Intel® Xeon® Processors, Data Center Products including boards, integrated systems, and RAID Storage
5244 Discussions
NUC13 (i5-1340P) issues with transfering files via USB
fommof
I've been using a NUC13 as my main PC for about two years.
Every 2 or 3 months I take a backup to external HDDs, muy total data is 6Tb stored in two SSDs in the NUC.
A month ago I started the backup routine, and I started getting errors in the middle of the transfer like "cannot find the USB device" etc and the speeds where flactuating from 200MB/s down to 10MB/s and vice versa.
I've tried every single USB port, several docking stations with several HDDs, several external USB HDDs and SSDs with the same result.
The problem occurs while transfering files with both File Explorer and Teracopy.
My system has the latest firmware and drivers and runs on Win11.
After weeks of testing and troubleshooting, the only way to actually take a backup without interruptions is to use a hub that significantly drops down the speeds to 10-20MB/s but that's ridicilous.
Honestly, I am seriously thinking of building a small desktop and ditch the NUC altogether.
Any suggestions, advice etc would be much appreciated.
Thanks in advance.
DeancR_Intel
Hi fommof,
Thank you for posting in Intel Communities!
Apologies for the delay on my response. We understand you have encountered an issue with your NUC. We would like to gently inform you that as of January 16, 2024, the Technical and Warranty Support for Intel's NUC 7 through NUC 13 Systems is now managed by ASUS. For any assistance regarding software, firmware, BIOS support, and security advisories, please visit ASUS Support at ASUS Support.
While we realize this may not be the response you were anticipating, engaging with ASUS technical support will ensure you receive the most specialized assistance, and we will not be monitoring this thread. For additional information, we encourage you to review the related articles.
Customer Support Services for Intel® NUC Products Has...
[NUC] NUC Service, Support, and Warranty Transition FAQs | Official Support | ASUS Global
Dean R.
