PCI 3 on 2600co
KDiet2
I was just told that the pcie gen 3 16x is locked. Is this true and is there a fix? Trying to take advantage of an NVIDIA GPU.
Daniel_O_Intel
It's a pretty short list of adapters that run at Gen3 speeds - http://www.intel.com/support/motherboards/server/sb/CS-034157.htm Server Products — PCIe* Gen 3 adapter support for Intel� Server Boards S2600/S2400/S1600/S1400
Judging from the technical advisory http://www.intel.com/support/motherboards/server/sb/CS-033827.htm Server Products — TA1021: PCIe* Gen 3.0 Add-in Adapter Support Issue , I don't think the x16 has anything to do with it.
DSilv11
Valued Contributor III
What CPU are you using?
