RES2CV240 & ESRT2 & RSTe
GTobi1
New Contributor II
Does ESRT2 work with RES2CV240 and if so is SATA/SAS RAID5 supported if the appropriate RAID key is used
Also does RSTe work with RES2CV240 and if so is SATA RAID5 supoorted if the appropriate RAID key is used.
GT
Edward_Z_Intel
ESRT2 supports up to 8 physical drives, and it doesn't support expander. RSTe supports expander, however drives/arrays connected through expander can't act as boot devices. Furthermore, when SAS is enabled, RSTe RAID 5 is disabled.
Edward_Z_Intel
