Annonces
5194 Discussions
RMM 3 command line status check
FKens
Débutant
3 978 Visites
I've got a few devices that have RMM loaded. I know it's an intel rmm and pretty sure it's RMM3.
What I don't know is what is the IP of the device and how to get it from just the command line.
I can get RMM3 to work on a few devices because I know the RMM IP. I was given the RMM IP to the other boxes but when I try it either times our or gives me an error or sends me to some default page.
I have CLI access to all the devices and have tried using the mmconfig (all linux) and it's not working. I thought I noticed another command but wasn't able to try it due to a forced reboot on my windows box but can't remember where I saw it.
I think the CLI instances (linux) are barebones so after the RMM3 was installed all access to the commands may have been removed. I tried looking for them in the /usr/local/somewhere/somewhere folder and didn't find it. I haven't attempted to actually find the file.
I would like to know if there is a way to use basic linux commands without having to download anything and list the RMM status of each device at least the IP.
Any assistance would be helpful.
0 Compliments
3 Réponses
DSilv11
Précieux contributeur III
2 828 Visites
IPMItool lan print 1
ipmitool lan print 3
ipmitool user list 1
ipmitool user list 3
first 2 will tell you if the BMC \ RMM is configured for access and the IPs
2nd 2 will tell you if any users accounts are enabled for access.
1 is the shared base board NIC and 3 is the dedicated RMM nic
FKens
Débutant
2 828 Visites
Doc silver;
Thanks, however I learned that the firewall may have been blocking me. Since then I've asked that they allow the RMM IP through. In one case they have.
I logged on to the device using putty and got the SMASH CLP prompt. I am going through the Intel_rmm_userguide_r1_4.pdf for what to do and it's not very helpful. I've typed sow help and it basically tells me to read the document I cited.
I tried the commands from an ssh putty session, you suggested and I get "No such file or directory".
Where do I run these commands?
0 Compliments
DSilv11
2 828 Visites
Those command would run on the local OS (assuming your Linux version has IPMItool installed.)
If you are reaching the RMM now it has a web based interface you can access by just opening a web browser to the IP address of the RMM. (HTTP:\\10.10.10.1)
IPMItool can also be installed on your local system and run over the network using the command syntax:
ipmitool -H10.10.10.1 -Uuserid -Ppassword lan print 1
However since the above command are to tell you the IP, & if any userids are enabled, it does not do a lot of good since you can't use the commands unless you already know the BMC user name and password and IP.
You can get ipmitool here http://sourceforge.net/projects/ipmitool/files/?source=navbar IPMItool - Browse Files at SourceForge.net if it is not on your linux box.
It includes instruction to compile from windows or you do a sheach for ipmitool.exe, SUN use to post a windows version pre-compliled.
IPMIutil is a sister utility for windows and is here http://ipmiutil.sourceforge.net/ ipmiutil - IPMI Management Utilities
I have not used it as much so not sure of all the syntax.
0 Compliments
Répondre
