RMM4 module not working
VArkh
have a system with a S2600CP4 board. I would like to enable its KVM features by adding a remote management module RMM4
I configured the module in Bios
But in BMC web concole I see that the module is not installed:
Why it does not work?
Hello Vityas,
Hope you are doing fine.
In order to activate the KVM, you will need the activation key RMM4.
You can search it by the product code AXXRMM4LITE.
Charlie_Intel
VArkh
I have AXXRMM4, not lite. Tell me please how and where I can activate it
Hello Vityas,
What is the BIOS firmware version that you have?
Charlie_Intel
VArkh
I post screen in first message with bios information.
se5c600.86b.02.06.0005
Hello Vityas,
I apologize for asking but we need to double check the information, are you able to perform an EFI firmware update?
Please try to run the browser as an administrator - right click on the application and then "run as administrator" and install the java package.
Charlie_Intel
VArkh
Thanks for the answer. I updated the firmware a few months ago. Do not I have the latest version now? Give please a link to it if not.
The latest version java is installed. I started the browser as administrator, but still writes that the module is not installed.
Hello Vityas,
We are wondering if the information provided worked for you and if you still need assistance?
Charlie_Intel
VArkh
Hello. I installed both updates. Unfortunately, the problem is not solved.
Hello Vityas,
This could be an issue with the RMM or the board.
We are going to contact you back as soon as possible to give you further assistance.
Charlie_Intel
Hello Vityas,
We are going to proceed and close this thread as we are already working on another case.
Charlie_Intel
