5285 Discussions
Receiving event log error for PS on S1200RP server
MDYCK
When I looked at the server event log in the RMM I saw events for the power supply redundancy. In the sensor readings it shows yellow with a warning and a reading of 0x0001. The event log shows the following entries:
PS1 StatusPower Supplyreports a predictive failure has been detected for the power supply - Deasserted
PS2 StatusPower Supplyreports a predictive failure has been detected for the power supply - Deasserted
Pwr Unit RedundPower Unitreports redundancy has been lost, but the unit is still functioning with the minimum amount of resources needed for normal operation - Asserted
Pwr Unit RedundPower Unitreports redundancy has been lost - Asserted
Is this something I need to be concerned with? I have not seen any other indications of failure. Are one or both of the Power Supplies beginning to fail?
Mike
Daniel_O_Intel
If it only happened once, I would not be concerned. If it happens again, i would first split the two power supplies onto different power circuits, to try to narrow it down (since it looks like both got affected at the same time).
Hejmo
By any luck, would you happen to have a copy of firmware package 02.01.0002 for S1200RPS ?
AlHill
@Hejmo One post is enough.  Stay with your original post.
