S1200btlr No Display no start
TSchm6
My Hardware
Mainboard S1200BTLR
CPU - Xeon E3 1265v2
Kingston RAM (KVR1333D3E9SK2/8G)
Intel SSD 330
Hitachi HDD 2T
Sony DVD Laufwerk
When I start the system (PowerOn) come one long beep.
No BIOS will shown on the screen and no other on the screen is seen
When I wait a time come the loog Beep again.
The Led signal is (0=on; x= off)
x0xxxx0
follow Test i have done:
-> change the RAM to other Slots -> the issue is the same.
-> using RAM from my other S1200 Systems -> the isuse is the same
-> start without RAM -> three beeps
-> diconnect all HDD and DVD and start the system -> the issue is the same
-> Remove the CPU and install the cpu again -> the same result
The power cables and Jumper are check.
Can help some one?
Tobi
Your LED code is missing an LED.
If you correct that we might have a better idea of the problem.
TSchm6
Here the LED Code
LSB MSB
during beep: X0x0 x000
before/after beep 0xxx xx0x
The Status LED
by power on: flash green
by the beep: flash orange
after the beep : flash orange
Neither of those status codes are in the POST Code Diagnostic LED Decoder section of the TPS.
The next thing I would suggest is accessing the RMM directly, if your serverboard has one, I see that it is optional.
If you are not familiar with the RMM, seek information from section 3.6.2 of the http://download.intel.com/support/motherboards/server/s1200bt/G13326-003_S1200BT_TPS_v1_0.pdf TPS. Let me know if you identify an RMM as part of your system. Let me know if you are able to get access to the server system logs from the RMM.
Jason
TSchm6
I've no RIMM, so I hvae no access to the board.
Okay, there is this http://www.intel.com/support/motherboards/server/sb/CS-029657.htm tool which may be of assistance.
I would guess you'll need to try something like this:
