5226 Discussions
S1200bts wont boot - show non-documented error
Hi I just reveived the s1200bts and it will not boot. These thing are connected to it:
  • 2x power cable
  • front panel
  • processor E3-1230 + box cooler
  • 1x 2GB ram module
  • nothing else
The board will not boot and shuts itself down after a while. No beeps, diagnostic led light up like this: 0x22h (0010 0010 = bit1 & bit5 on, others off) which is NOT specified in documentation.
what has been also tried without success (LED still show 0x22h):
  • pci-e VGA
  • connect SATA disks
  • connect intrusion detection
  • change RAMs
  • take out RAMs = 3 beeps
Could someone please help me out?
Check if the RAM is compatible with the motherboard+ processor combination.
Try different power supply.
Try different processor.
I recommend a Clear CMOS after each change.
If the system doesn't boot with only MB + Proc + RAM + Pwr, then it is most likely the motherboard.
