S2600 Server shutdown issue
SFull2
Just has a S2600 server shutdown without notice. Following is from Event logs just like some thought on what is most likely cause. Server is UPS protected and other servers on same UPS had no issues.
Physical removal of power cords from power supplies and reset server booted fine?
1500 05/11/2016 14:01:19 Pwr Unit Status Power Unit reports the power unit has suffered a failure - Deasserted
1499 05/11/2016 14:01:17 Pwr Unit Status Power Unit reports the power unit is powered off or being powered down - Deasserted
1498 05/11/2016 14:01:12 Pwr Unit Status Power Unit reports the power unit is powered off or being powered down - Asserted
1497 05/11/2016 14:01:11 Pwr Unit Status Power Unit reports the power unit has suffered a failure - Asserted
1496 05/11/2016 13:59:44 Pwr Unit Redund Power Unit reports redundancy has been lost and there are insufficient resources to maintain normal operation - Asserted
1495 05/11/2016 13:59:43 PS2 Status Power Supply reports the power supply's input (AC/DC) has been lost - Asserted
1494 05/11/2016 13:59:43 Pwr Unit Status Power Unit reports the power unit is powered off or being powered down - Asserted
1493 05/11/2016 13:59:42 Pwr Unit Redund Power Unit reports redundancy has been lost, but the unit is still functioning with the minimum amount of resources needed for normal operation - Asserted
1492 05/11/2016 13:59:42 Pwr Unit Redund Power Unit reports redundancy has been lost - Asserted
1491 05/11/2016 13:59:41 PS1 Status Power Supply reports the power supply's input (AC/DC) has been lost - Asserted
1490 05/11/2016 13:57:53 Button Button / Switch reports the power button has been pressed - Asserted
1489 05/11/2016 13:11:18 BMC FW Health Management Subsystem Health 'P2 Therm Ctrl %' sensor has failed and may not be providing a valid reading - Asserted
1488 05/11/2016 13:11:18 BMC FW Health Management Subsystem Health 'P1 Therm Ctrl %' sensor has failed and may not be providing a valid reading - Asserted
1487 05/11/2016 13:09:55 BMC FW Health Management Subsystem Health 'SSB Temp' sensor has failed and may not be providing a valid reading - Asserted
1486 05/11/2016 13:09:55 BMC FW Health Management Subsystem Health '' sensor has failed and may not be providing a valid reading - Asserted
1485 05/11/2016 13:09:54 BMC FW Health Management Subsystem Health 'P2 Therm Margin' sensor has failed and may not be providing a valid reading - Asserted
1484 05/11/2016 13:09:54 BMC FW Health Management Subsystem Health 'P1 Therm Margin' sensor has failed and may not be providing a valid reading - Asserted
1483 05/11/2016 13:09:37 BB +1.05V P1Vccp Voltage reports the sensor is in a low, critical, and going lower state - Asserted
1482 05/11/2016 13:09:37 BB +1.05V P1Vccp Voltage reports the sensor is in a low, but non-critical, and going lower state - Asserted
1481 05/11/2016 13:09:12 Pwr Unit Status Power Unit reports the power unit has suffered a failure - Deasserted
1480 05/11/2016 13:09:10 Pwr Unit Status Power Unit reports the power unit is powered off or being powered down - Deasserted
1479 05/11/2016 13:09:05 Pwr Unit Status Power Unit reports the power unit is powered off or being powered down - Asserted
1478 05/11/2016 13:09:05 Pwr Unit Status Power Unit reports the power unit has suffered a failure - Asserted
1475 05/11/2016 13:09:12 Pwr Unit Status Power Unit reports the power unit has suffered a failure - Deasserted
1474 05/11/2016 13:09:10 Pwr Unit Status Power Unit reports the power unit is powered off or being powered down - Deasserted
1473 05/11/2016 13:09:05 Pwr Unit Status Power Unit reports the power unit is powered off or being powered down - Asserted
1472 05/11/2016 13:09:05 Pwr Unit Status Power Unit reports the power unit has suffered a failure - Asserted
