公告
S2600CP No video
TFolk
初學者
10,109 檢視
Hello all,
I purchased a used S2600CP and got around to installing everything. I hooked it up and i do not get any display at all from VGA on my monitor.
I tried clearing the CMOS which did nothing and then i loaded the BIOS onto a USB and tried to recover it but i dont think its recovering.
Then I tried installing an old graphics card to see if that would work and still do not get any display.
The USB stick does not even light up when i plug it into the back of the board so im wondering if the board is bad?
I do have a flashing Amber Light on the Status LED and have attached what the manual says but i am not certain what those issues are.
Anything I should try to get some display?
Thanks!
0 積分
1 解決方案
SJoha3
初學者
7,237 檢視
I had the same problem, this is likely because of an old bios version, you will need a v1 xeon to update the bios to use v2 xeon.
Updating the bios is also tricky, i had this board and it bricked by updating from old to newest bios version (EVEN THOUGH THE INSTRUCTIONS SAY IT'S OKAY)
you will need to go through each update. (I'm still waiting for my 2nd board to try again...)
But yeah after my board bricked i started googling and reading around and everybody seems to be saying that no big jumps in bios versions or you will brick it.
在原始文章中檢視解決方案
15 回應
員工
7,237 檢視
Hello th3godf4th3r,
I am really sorry on the problems at hand with your S2600CP board with no videos.
Thank you for the troubleshooting steps provided.
Could you please let me know the type of chassis you are using.
The power Supply use?
CPU model?
Memory type and size and manufacturer?
When pushing the power button are you getting any type of lights on the board.?
If there is anything else we can help please feel free to ask.
Henry A.
TFolk
初學者
7,237 檢視
Should have listed this to begin with, sorry about that!
Cooler Master Cosmos II case
Evga 600w PSU
E5-2680v2
Dell Poweredge 32gb 2rx4 DDR3 Ram
When I push power like I said above the computer turns on and boots but I get no display at all. The only light that is on besides a small green one closer to the corner is the Amber 1hz flashing light status light which the manual says what I included in that screenshot.
TFolk
初學者
7,237 檢視
To confirm, the board system led light blinks green at first start and then after about 15 seconds the light goes to blinking Amber and stays like that until the power is cut.
The only other light is the solid green HDD led light.
TFolk
初學者
7,237 檢視
I am fairly certain the board is bad.
I cannot get any display at all on a brand new monitor that just came out of the box, i can plug in a graphics card and try using vga and or hdmi and still do not get any display.
I have tried countless times resetting the CMOS and trying to recover the bios but cannot get anything to display on the screen.
The board will be shipped back on monday unless we can figure out what is wrong.
TFolk
初學者
7,237 檢視
Speaking with the seller, they seem to think that if i get (1) E5-2609 CPU for example, I will be able to get a display and be able to update the BIOS to the most recent which would then support the E5-2680v2.
Does this sound right?
GRIFFCOMM
新貢獻者 I
7,237 檢視
Confirm (some how) the CPU is ok, ive had bad CPUs from the E5 generation (burn out), with very small black marks on the underside of the CPU. The basics were the CPU didnt work.
However if the "seller" says try another CPU, it could be there pointing to you having a bad CPU or theres a BIOS issue with the CPU you are using in that board (Intel will have more info on firmware levels and CPU support).
Ive had no display with UEFI setup BIOS as well, but a BIOS reset should cure that.
I would start checking BIOS lights with a bad CPU at this point. Does it do the same with no CPU installed?
員工
7,237 檢視
Hello th3godf4th3r,
Thank you for your updated information.
For what I can see the only part not compatible is the memory.
This can be found on the Intel https://ark.intel.com/products/56333/Intel-Server-Board-S2600CP2 ARK page.
Also, what the reseller is also correct, but without knowing the BIOS version that can or can not be true. It could be a good troubleshooting to test with an older CPU.
Without a CPU, it should beep 3 times as soon as you turn on the server.
Henry A.
TFolk
初學者
7,237 檢視
wow not sure how i ended up without DDR3 ram, total space cadet move on my part.
I will pick up a stick tomorrow and test it out. My guess is that will help.
Ill post back tomorrow after install.
TFolk
初學者
7,237 檢視
Never mind, double checked and i was reading the rank. I have attached the specs, it should work.
GRIFFCOMM
新貢獻者 I
7,237 檢視
Is your RAM listed on the compatibility list (link below)? (we normally use Kingston)
http://www.cmtlabs.com/2012/memCertPartSearchResultsAll.asp?bNav=True&sManuf=Intel&outside=False&sMN=S2600CP CMTL > Search > Tested Motherboard > Results
SJoha3
初學者
7,238 檢視
TFolk
初學者
7,237 檢視
Thanks for the reply Johnny, that is good to know.
I ordered an old v1 cpu to try and get some display so that I can update the bios.
Also good to hear about no big bios updates. Intel is this correct? If so, is there a list of bios updates for the board so I could update in order?
TFolk
初學者
7,237 檢視
Alright, an update.
I got one E5-2609v1 CPU and Kingston KVR13E9/4IK 4GB memory.
i just installed and tried to start and now i am met with 1 beep, pause, 5 beeps, pause, 2 beeps pause 1 beep.
What does this mean and what should i try now? I get no display still.
TFolk
初學者
7,237 檢視
Should have waited to post that, quick fix, just swapped the CPU from slot 2 to slot 1 and it fired up.
Now my next issue i guess is i need a usb keyboard because it doesnt seem to sense my bluetooth dongle.
I am finally able to see display however!
員工
7,237 檢視
Hi there th3godf4th3r,
I am glad to hear you were able to resolve the issue with the system. Yes, the board requires a specific firmware level to fully support your V2 processor capabilities. You always need to use CPU Socket 1 first to boot up the system.
Depending on the BIOS version your system is running with you might need to install a mid-level version first. For this, I would recommend reviewing the Release Notes for the firmware package. This will tell you the pre-requisites for the install.
Again, I am glad to hear you were able to sort this one out. Feel free to reach out our support team if you need anything else.
David A.
回覆
