Intel® Xeon® Processors, Data Center Products including boards, integrated systems, and RAID Storage
S2600CW Older Firmware
AHans8
I have an old S2600CWS server board which now requires a firmware update, but I am unable to find the required update on Intel's download centre. The newer versions are available but because my board is running such an old version I need to do an interim update before going to the newer update. The interim update is the one I am unable to locate.
Current Firmware - 01.01.0027
Required Interim Firmware - 01.01.0029
The 2 updates after 01.01.0029 are on the Intel download page. (01.01.1029 & 1.01.3029)
It does say before I can go to at least 01.01.1029 or 3029 (latest) I must update to 01.01.0029 otherwise it may "brick" the board.
Does anyone know where I can get the "missing" firmware from, to allow me to fully update to the latest version.
Thanks in advance.
vish1
Hello AHans8,
Greetings!!
Thank you for trusting Intel with your business. As with all good things, your product has reached the end of its interactive technical support life. However, you can find Intel® Server Board S2600CW2 recommendations at Intel Community forums and additional information at the Discontinued Products website. It is our pleasure to continue to serve you with the next generation of Intel innovation at Intel.com.
Vishal Shet P
