5301 Discussions
S2600CWR Board - All LEDs flashing
Trooper
I'm running a S2600CWR board, with latest firmware installed.
Twice this has happened - The server crashes, then all the LEDs on the board will flash simultaneously, about once or twice a second.
I've had to pull the power cord from the P/S for a minute, then it restarts normally.
If I just flip the power switch off then on, it doesn't come back. It just immediately starts flashing LEDs.
The BMC log only shows that power was removed.
Does anyone know what might cause this?
This may be related. I've also had the server reboot randomly. The BMC log again shows that power was removed. I've since added a power line conditioner and haven't seen the issue since. It was previously running on house power. But I've never had power issues with any other machine.
SergioS_Intel
Hello Tropper,
In addition to the information provided before, we would like to share with you the list of supported power supplies for the Intel® Server Board S2600CW Family for your future reference:
https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/S2600CW_P4000G_Configuration_Guide.pdf
Page 42.
This because you mentioned that you were planning to install a EVGA; Model: 220-GA-0750-X1
Sergio S.
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
SergioS_Intel
Hello Trooper,
Thank you for contacting Intel Customer Support.
Please help us with proving some additional information:
1. Is this a new installation or your system was working normally before?
2. Can you please share with us the latest SEL logs of your server?
3. Was there any recent changes on the system? Have you tried testing different a different power supply?
4. On your post you mentioned that you recently installed a power line conditioner, have you tried testing your system by connecting it to the wall directly?
5. Please provide us more information about your system configuration, power supply and processor model, memory, etc.
You can find more information about the different LED lights here:
https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/S2600CW_TPS.pdf Page 85
We will be looking forward to your reply.
Sergio S.
Trooper
Sergio
Thanks for the response.
This is a new system.
All components are new except the two processors, which were taken from another system.
I have uploaded a couple SEL logs and a couple debug files.
I saved then cleared the logs on 5/12 after the first event which occurred on or just before 5/7.
Then it happened again on 5/16 (I think it was).
The system was just recently built, so everything is new/changed.
I have not tried a different power supply, but that is next.
The current P/S is an EVGA; Model: 220-GA-0750-X1
I was waiting for it to happen again, but it has not.
I have not tried plugging directly into the wall.
I did review the document about LED indicators, but I did not see my symptom listed.
Here is some info:
Host Power Status :
Host is currently ON
Remote Management Module key :
Installed
Device (BMC) Available :
Yes
BMC FW Build Time :
2020-08-18 04:32:56
BIOS ID :
SE5C610.86B.01.01.1029.090220201031
BMC FW Rev :
1.61.12390
Boot FW Rev :
1.07
SDR Package Version :
SDR Package 1.15
Mgmt Engine (ME) FW Rev :
03.01.03.072
Baseboard Serial Number :
FWCT71610549
Manufacturing Date :
2017-04-28   15:40
Manufacturer :
Intel Corporation
Product Name :
S2600CWR
Serial Number:
FWCT71610549
Part/Model Number :
H12881-271
FRU File ID :
FRU Ver 1.14
Socket Designation : CPU1
Manufacturer : Intel(R) Corporation
Version : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
Processor Signature : 0x406F1
Processor Type : Central Processor
Family : Intel(R) Xeon(R)
Speed : 2.4 GHz
Number of Cores : 14
Voltage : 1.8 V
Socket Type : Socket LGA2011-3
Status : Populated, Enabled
Serial Number :
Asset Tag :
Part Number :
Socket Designation : CPU2
Speed : 2.4 GHz
Voltage : 1.8 V
Serial Number :
Asset Tag :
Part Number :
Memory:
Slot Number      Size       Type      Speed   Manufacturer   Serial Number   Part Number
DIMM_A1          16384   DDR4    2400     Hynix                  116504E2           HMA42GR7AFR4N-UH
DIMM_B1          16384   DDR4    2400     Hynix                  116504D1          HMA42GR7AFR4N-UH
DIMM_C1          16384   DDR4    2400     Hynix                  116507E6           HMA42GR7AFR4N-UH
DIMM_D1          16384   DDR4    2400     Hynix                  116504E0           HMA42GR7AFR4N-UH
DIMM_E1          16384   DDR4    2400     Hynix                  11650889           HMA42GR7AFR4N-UH
DIMM_F1           16384   DDR4    2400     Hynix                  116504C2           HMA42GR7AFR4N-UH
DIMM_G1          16384   DDR4    2400     Hynix                  11650451           HMA42GR7AFR4N-UH
DIMM_H1          16384   DDR4    2400     Hynix                  116504D2          HMA42GR7AFR4N-UH
SergioS_Intel
Hello Trooper,
We appreciate the time taken to provide us the SEL logs and the additional information.
Upon checking the logs we noticed that the latest entries are from 05/12/2021 00:11:56 with no power related errors. Since you mentioned that you have not experienced the issue again, you can keep monitoring your system and if the problem happens again, please provide us a new set of SEL logs and also try testing with another power supply.
If you wish I can follow up your case on 5/28/2021 in order to check that the issue did not happen again or if you wish a different date please let me know.
Sergio S.
SergioS_Intel
Hello Trooper,
We are following your thread and would like to know if you are still experiencing the any problems with your system.
Sergio S.
Trooper
Hi Sergio
So far no more issues.
I was still wondering if Intel has an explanation for all LEDs blinking.
That symptom is not described in the documents.
But maybe with power issues, all bets are off as anything could happen.
Other than that, I think this is all set.
My fear was there was something wrong with the board, but I don't think that is the case.
Maybe an overly-sensitive power supply.
I still have not tried swapping P/S, as I would need to take one from a working system.
Which I have, but I do not have a spare P/S.
SergioS_Intel
Hello Tropper,
The problem regarding all the LEDs blinking can be related with power issues that you had in the past. Can you please let us know if you noticed this issue again or any other power related problems? If so, please feel free to share the SEL and debug logs.
Sergio S.
Trooper
My issue appears to be a power supply issue.
I had another event where the server just powered off for no reason.
I eventually got it to power on, but got the blinking LEDs again.
I finally swapped the power supply with a similar server, and the symptoms are now on the other server.
And the first server is running fine, as of right now.
The P/S is brand new. I am going to request an RMA.
Thanks for all your help.
Bill
SergioS_Intel
Hello Tropper,
We are glad to hear that you were able to resolve your problem, please let us know if you want to keep this thread open until you replace the power supply and test it or if there is anything else we can do for you.
Sergio S.
Trooper
It would be nice to leave the thread open.
But it might be a week or so before I get the P/S replaced.
EVGA doesn't have a great RMA process.
I have a hunch as to why all the LEDs were blinking.
As my other board (S2600CO) did the same thing when using the bad power supply.
When the server is first powered on, all the LEDs blink once. I assume this is normal.
I suspect that just as the server powers on, the power supply stops delivering power.
So the server shuts down. Then the power supply gives power again, the LEDs blink, then the power supply shuts down again.
And this repeats over and over, and that is why all the LEDs blink on and off.
SergioS_Intel
Hello Tropper,
We can leave this thread open as long as you need. We can send you a follow-up next with on 6/21/2021. If you prefer a different date, please let us know.
Additionally, as you mentioned, the problem of all the LEDs light blinking point to a bad power supply unit.
We will be looking forward to your response.
Sergio S.
SergioS_Intel
Hello Tropper,
In order to continue troubleshooting your problem, we are escalating this case to our engineering team. We will keep you posted as soon as we get an update.
Sergio S.
SergioS_Intel
Hello Tropper,
Page 42.
Sergio S.
SergioS_Intel
Hello Tropper,
We are following your case and would like to know if after replacing the power supply the problem continued.
Sergio S.
Trooper
Hi
I have not yet received the replacement power supply.
I am expecting it later this week.
SergioS_Intel
Hello Tropper,
Thank you for the update, we will follow up your case next week.
Sergio S.
SergioS_Intel
Hello Tropper,
We are following your case and would like to know if you received and replaced the power supply for your system and if you did, if the problem continues.
Sergio S.
Trooper
Hi Sergio
My apologies for the delay.
The new power supply does appear to have resolved the issue.
Although I’ve only had it installed for one day, I have repeatedly powered the server on/off without a single incident.
To your earlier point about using supported hardware – Lesson learned.
I will mark this post as Resolved.
Thanks again for all the responses.
Bill
SergioS_Intel
Hello Tropper,
We are glad to hear that we were able to assist you. Please do not hesitate to contact us in case you need more assistance.
Sergio S.
