S5500BC Problems
Hi
I am building a server with S5500BC motherboard, E5506 xeon processor, STS100A Thermal Solution, 3 x 1TB Western Digital Harddrive in Raid 5, 4 x 2 GB Kingston RAM, optical drive on a third party case with 650W power supply
System did not start, after trouble shooting found that system works fine with 1 processor but does not start when second processor is put in... no screen display, status led turns amber
Any suggestions would be appreciated
Vish
Daniel_O_Intel
Make sure you've got sufficient amperage on the 12 volt rail.
You can also try with 2 procs, but only one DIMM.
Hi Thank you for your answer, believe that is the problem.
VAlle
Agree with DanO on this check that the PSU has the kick to do the board and 2 processors.
