SELVIEW starting problem
SPetr3
Hi everybody,
I have a problem with my SC5650WS chassis with S5520SC board. SELVIEW seems to freeze at loading the IPMI drivers when starting through the EFI shell. I am also unable to start SELVIEW in Windows because when installing imbdriver I receive a message that msipmi driver alredy installed and it prevents me from installing imbdriver. How can I solve this problems and launch SELVIEW?
Edward_Z_Intel
Which version of SELVIEW are you using? Try this one: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17933 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17933
For Windows, what's the exact error message when you run install.cmd to install the IMBdriver? You may want to start the command prompt as Administrator first.
GBatt
Hello, I have exactly the same problem with Intel S5520HC and SC5650DP, I have 2 Xeon e5620
Please help us, thanx
David_A_Intel
In this particular case, I would recommend using the newer version of this utility which is now called https://downloadcenter.intel.com/download/18895/Intel-System-Information-Retrieval-Utility-for-Windows- Intel System Information Retrieval Utility.
If needed, you may use other utilities such as the https://downloadcenter.intel.com/download/24942/Intel-System-Management-Software-Intel-Active-System-Console Intel Active System Console. You may also configure the http://download.intel.com/support/motherboards/server/sb/intel_rmm4_ibwc_userguide_r2_72.pdf Integrated BMC Console; both of these offer the option to get the logs of the system.
DSilv11
Valued Contributor III
You can try loading the EFI IPMI driver before starting SELVIEW
FS0:> load ipmi.efi
FS0:> selview
