SRCSATAWB
Hi
I've just built a small server based on S3420GPLC 2 Seagate SAS drives and 4 Intel SSD X-25-M drives. Everything is inside a SC5650BRP case connected through a Intel SRCSATAWB and axx6drv3g drive backplane expander.
Now when controller is booting is showing me that "SAS drives were detected but this controller does not support SAS drives"
My question is: Is there anyway that I can make this controller work properly with SAS drives? Any RAID configuration including those 2 SAS drives will be stable? What can I do to disable that message?
Thank you!
Daniel_O_Intel
Unfortunately, that message is pretty literal. Even if you got it to work for a little bit, your data is not going to be stable on that kind of setup.
crisu_b,
The SRCSATAWB is a SATA only controller. It's not compatible with SAS disk drives. The SRCSASRB would be an equivalent SAS RAID controlller. The SAS controllers wiil work with both SAS and SATA disks.
John
