Server response slow
Ab11
Info: We have 2 servers with the following configuration
Server 1 configuration:
Server chassis: IBM System X3630 M4 Rack Server
Processor: Intel Xeon E5-2420 (6 core, 15MB, 1.9 GHz single CPU)
RAM: 8GB
RAID controller card: M5110 RAID
HDD: 3x 1TB (RAID 1) and 1x 1TB (RAID 0)
HDD type: SATA (Seagate Constellation ES.3)
RAID configuration details: Totally 7 HDDs are connected to the server (All are 1TB SATA HDDs). We have configured 3 RAID1 pairs using 6 HDDS (Each RAID1 is equal to 1TB) and 1 HDD as RAID0.
First RAID1 has 4 partitions. One is for OS and other 3 are used for just keeping very less accessed/ less important waste files).
Other 2 RAID1 HDDs have 4 partitions in each and all are shared over LAN.
RAID0 HDD has 8 partitions with low level data and it is also shared over LAN.
Network: 2x 1 Gbps (With static routing)
OS: Windows Server 2012 Standard R2
Antivirus and firewall: Symantec Endpoint Protection 12.4 (Firewall disabled)
Server 2 configuration:
Server chassis: CHENBRO CHASIS Model: RM-41416B
Motherboard: Intel Server board S2600CP4
Processor: Intel XEON E5-2630 V2 (6 core, 15MB, 2.6 GHz single CPU)
RAM: 8GB RAM Samsung ECC RDIMM (2 no's)
RAID controller: LSI MegaRAID 9271-4i SGL SATA+SAS Part No: LSI00328
RAID card to HDD connector: Mini SAS to 4 SATA CABLE SAS PCI D33289-003 BIZLINK (Intel)
Network: 1 Gbps (2 no's with route add enabled)
RAID configuration details: Same as Server 1
<p style="margin-top:...
Ab11
Please note that i completely edited the post for better understanding..
AP16
Valued Contributor III
Try the bcdedit /set {default} USEPLATFORMCLOCK on trick (reboot required). Also, what network adapter you have in server 2?
Ab11
Thank you for the comments.
After monitoring the server using 'perfmon' I got to know that the disk read/write speed seen bit slow. I got these 5 sectors as bad.
Perfmon result:
Server (C:)\%disk (C:)\Avg. Disk (0 C: X: Y: Z:)\Avg. (0 C: X: Y: Z:)\Avg. (0 C: X: Y: Z:)\Avg. Read time sec/Write Disk Read Q Length Disk sec/Transfer Disk sec/Write
Server 1 7.136396 0.5939E-3 0.07135 0.60109E-3 0.593206E-3
Server 2 8.3509 7.1190E-3 0.08348 6.82229E-3 6.15297E-3
My OS is installed in disc C. By looking in to these I can tell that OS may become slow by the slow response of read/write operation in C but in the result of loop test I don't understand that how the read/write operation in disk C effect the loop test. Is this because OS became slow by the read/write operation in disk C? Or is this due to something else? Please enlighten me...
Ab11
Thank you for the reply JFFulcrum
bcdedit /set {default} USEPLATFORMCLOCK yes did not solve the problem instead the server got much slower than before so I rolled back. Is there any other way track the problem?
AP16
Well, check also with http://www.resplendence.com/latmon Resplendence Software - LatencyMon: suitability checker for real-time audio and other tasks tool, some driver may be source of trouble.
