5307 Diskussionen
Stitched Rank Margin Test Log Format
tester_1
Einsteiger
797Aufrufe
Hi could someone help me to figure out the format for the RMT logs?
I am currently using the Rank Margin Test to validate some DIMMs for an Intel Xeon Silver 4310 CPU (Ice Lake). I am able to run the Stitched Rank Margin Test, but I am having issues with the log output. I am using the Memory Assistant for Intel Xeon Platforms 2.8.26.0 application to analyze the RMT serial log output and the main tab in the application runs fine, but the UPM tab is not letting me click on "Run UPM" due to lack of DIMM information. Could you provide an example of what information the log is supposed to include so that UPM will run properly?
Output of RMT test:
Log that I compiled from serial output of RMT test:
Memory Assistant for Intel Xeon Platforms 2.8.26.0 Main Tab:
Memory Assistant for Intel Xeon Platforms 2.8.26.0 UPM Tab:
9 Antworten
Steve_Jerome22
Mitarbeiter
790Aufrufe
Hi tester_1,
Greetings for the day!
Thanks for contacting Intel Customer Support with your query:
Please refer the below document for Memory Assistant for Intel® Xeon® Platforms.
Note: This document requires Intel RDC access.
For RDC access, you can refer to the below article.
How to Apply for an Intel® Resource and Documentation Center (RDC)...
Jerome
tester_1
Einsteiger
784Aufrufe
Hi Jerome,
Thank you for providing me the documents, but it does not contain an example of what the log file should look like/include. I also looked at the Whitley Platform DDR4 EV Tools and Methodology (ID: 611498) document and it does not show what the full log should include. I think I am missing some DIMM information that is preventing me from running the UPM assessment, so would it be possible for you to provide a full example of a stitched RMT log?
James
Yesu27
Mitarbeiter
778Aufrufe
Hello tester_1,
Thank you for your response.
Kindly provide the environment details, including the server model and operating system, so that we can review this internally and assist you accordingly.
Yesu27_Intel
tester_1
Einsteiger
773Aufrufe
Hi Yesu_27,
Thank you for taking a look at the issue. I am currently running WilsonCity System BIOS Version: K13P1N12 Date: "09/30/2022" with Ubuntu 22.04.5 LTS. I am running this on an Everpure Flashblade S200. I just wanted to note that the output the RMT test is the serial output when the system is booting up. Also, I was reading the Whitley/Cedar Island DDR EV overview and tool update document (ID: 621731) and saw that there was a DIMMINFO table in the serial log. Do you know how to adjust the BIOS or any settings for the DIMMINFO table to show up and how would I include it in the RMT log?
DIMMINFO Table:
James
Steve_Jerome22
Mitarbeiter
768Aufrufe
Hello tester_1,
Thanks for sharing the requested information, please allow us some time to check and provide you with an update as soon as possible.
Thanks for your understanding.
Jerome
Steve_Jerome22
Mitarbeiter
764Aufrufe
Hello tester_1,
Since the query is out of our scope, we will be transferring the case to the concern team.
You will be assisted further on this case by Intel SDP team.
Jerome
Steve_Jerome22
Mitarbeiter
761Aufrufe
Hello tester_1,
Apologies, kindly ignore the previous post.
We request to open a new ticket in the Intel Software Development Platform Support Center (Intel SDP) using the following link http://www.intel.com/sdp
Or if you have access to Intel Premier Support, you can open an IPS support ticket
https://premiersupport.intel.com/
Jerome
tester_1
Einsteiger
642Aufrufe
Hi Jerome,
Thank you for letting me know. I have created an IPS support ticket.
Best,
James
Dineshbabu
Mitarbeiter
637Aufrufe
Hi tester_1,
Greetings!
Thank you for your response. Since you have created IPS ticket, we are closing this request. Please don’t hesitate to reach out with any further questions in the future. Feel free to start a new conversation, as this thread will no longer be monitored.
Dinesh
Antworten
