Intel® Xeon® Processors, Data Center Products including boards, integrated systems, and RAID Storage
5266 Discussions
Xeon W-3400 non-X and Memory tuning
EricTrilog
I understand that the Xeon W-3400 X series are overclockable and the non-X series are not. Is it still possible to run higher DRAM frequencies with the non-X series?
For example, in my case running the W-3455 on an Asus W790 Sage motherboard, would an XMP profile of 5600mhz be possible?
NormanS_Intel
Hello EricTrilog,
Thank you for posting in the community!
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns. Therefore, I will be moving this discussion to our Server Forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Norman S.
Poojitha
Hi EricTrilog,
Thank you for contacting Intel support. We kindly request you to confirm the following steps to identify if your system is compatible with Intel® XMP:
1)Kindly check if the motherboard is listed as compatible with Intel® XMP by confirming this with the manufacturer.
2)please check if the memory module is Intel® XMP Certified.
please note that unlocked features are available with select chipsets and processor combinations. However, altering the clock frequency or voltage settings may void any product warranties and could result in reduced stability, security, performance, and lifespan of the processor and other components. We recommend checking with your system and component manufacturers for further details.
For more information, you can refer to the following link: https://www.intel.com/content/www/us/en/support/articles/000060130.html
Additionally, for details on Intel® Extreme Memory Profile, please refer to the link below:
https://www.intel.com/content/www/us/en/products/docs/processors/xeon/w-3400-w-2400-workstation-platform-brief.html
We appreciate your understanding!
Poojitha
EricTrilog
Hi Poojitha,
As mentioned, I am running the following configuration,
Motherboard: Asus Pro WS W790E-Sage SE ( XMP Certified )
https://www.asus.com/ca-en/motherboards-components/motherboards/workstation/pro-ws-w790e-sage-se/
Processor:
Intel(R) Xeon(R) w7-3455 ( XMP unclear )
Memory: ( XMP Certified )
https://v-color.net/products/ddr5-oc-r-dimm-intel-w790-workstation-memory-copy
The 4x64gb at 5600MHz, which is in the supported memory list of the motherboard.
The documentation regarding the non-x processors permitting XMP profiles is unclear. Can you confirm or deny that this processor can handle XMP profiles?
Poojitha
Hi EricTrilog,
Thank you for your response. We kindly request some time to check the details and provide you with an update.
We appreciate your understanding!'
Poojitha
vish1
Hi EricTrilog,
Regarding the support for XMP (Extreme Memory Profile) on Intel® Xeon® W7-3455 processors. As you correctly noted, XMP profiles are not supported on the W7-3455 processors. This feature is exclusively available on the "X" series processors.
For your reference, you can find a comprehensive list of processors that support XMP profiles in the Intel® XMP 3.0 Memory for Intel® Core™ Processors Datasheet. The datasheet is available for download in Excel format at the following link: Intel® XMP 3.0 Memory for Intel® Core™ Processors Datasheet.
Additionally, I would like to highlight that the maximum memory speed supported by the Intel® Xeon® W7-3455 processors is 4800MHz. You can find more detailed specifications for this processor series at the following link: Intel® Xeon® W7-3455 Processor Specifications.
If you have any further questions or need additional assistance, please do not hesitate to reach out.
Vishal Shet P
Poojitha
Hi EricTrilog,
Greetings for the day!
We are following up to check if you were able to find the information we requested. Kindly confirm at your earliest convenience, so that we can continue assisting you in resolving this matter.
Poojitha
Poojitha
Hi EricTrilog,
Poojitha
EricTrilog
Hi Poojitha,
Yes the information provided answered my question.
Thanks!
pujeeth
Hello EricTrilog,
Greetings!
Thank you for the update, we will go ahead and close this case.
We will proceed to close this case. If you find that you still required assistance, we kindly request you to respond to the case. This will allow us to either reopen the current case or initiate a new one.
Pujeeth
Poojitha
Hi EricTrilog,
Greetings of the day!
Thank you for confirmation. We will go ahead and close this case.
Thank you for your time and cooperation. It would be great if you could spare some of your time and provide us a feedback on the service provided. Your input will help us improve our support.
“You may receive an invitation to take a survey in a few days. We value your feedback and look forward to hearing about your support experience.”
kindly reach out to us we are happy to help you.
Poojitha
