I have 11th Gen Intel(R) Core(TM) i7-1185GRE @ 2.80GHz processor, and I downloaded bsp package for yocto build, I didn't make any changes, and it fails the following build:
bitbake mc:x86-rt-2020:core-image-sato-sdk
I have attached log files. Please review.
Thank you,
David
Hello dxy_tiger,
Thank you for raising this concern through the Intel Community.
I understand that you are using an 11th Gen Intel® Core™ i7-1185GRE processor and are encountering a build failure when running the following command without making any BSP modifications:
To properly investigate this issue, could you please provide the following information:
- Where did you download the BSP package? If possible, please share the download link.
- Are you using Windows or Linux as your host operating system?
- Is this the first time you have encountered this issue, or has it occurred previously?
Once we have these details, we will be able to proceed with a more thorough investigation.
John M.
Hi John,
I downloaded from Intel:
repo init -u git@github.com:intel/iotg-yocto-ese-manifest.git -b refs/tags/release-130_tgl_h-mr6 -g all
I'm using Ubuntu Linux:
Kernel: Linux vs3-i9 6.8.0-85-generic #85~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Fri Sep 19 16:18:59 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
Ubuntu: VERSION="22.04.1 LTS (Jammy Jellyfish)"
This is the first time.
Steps to build:
cd build/
. ../intel-embedded-system-enabling/oe-init-build-env .
I have fixed a few of easy git branch issues, such as change master to main:
meta/recipes-extended/cracklib/cracklib_2.9.8.bb
I have attached log files when initiated the case.
If you need more info, please let me know.
Thank you,
Dxy_Tiger
Hi dxy_tiger,
Thank you for providing the detailed information and log files regarding your Yocto build attempt.
I will need to investigate this issue internally with our team to determine the cause of the build failure and the steps required to resolve it. Once I have more information, I will get back to you with guidance or next steps.
In the meantime, if there are any additional logs, error messages, or details about your environment that you haven’t shared yet, please feel free to send them they may help expedite the investigation.
Thank you for your patience.
John M.
Hi dxy_tiger,
We understand how frustrating this situation can be. Based on our review, the issue appears to be related to the operating system loading or installation process. To ensure you receive the most accurate and effective support, we kindly recommend reaching out to your operating system distribution’s support team for further assistance.
Since this concern is not related with us I will now proceed to close this thread.
Thank you and have a great day!
John M.
