Could you please confirm the exact BIOS/UEFI version currently installed on the system?
In the BIOS, is TME-MT explicitly enabled, and what is the configured value for the TME-MT / TDX Key Split? A non-zero value is typically required for TDX functionality.
Is ACPI S3 explicitly disabled in the BIOS, as TDX is incompatible with S3?
Which Linux distribution and kernel version are you currently running?
Are you using an Intel-provided kernel, a distribution kernel, or a custom-compiled kernel?
Could you confirm whether the system is booted in UEFI mode (not Legacy/CSM)?
- Is Secure Boot enabled, and if so, have you verified that it is not preventing the TDX-related components from loading?
- Have you tested with a newer BIOS or firmware release, if available, as several Sapphire Rapids TDX issues have been resolved through firmware updates?
Your suspicion regarding BIOS completeness, particularly the TME-MT / TDX key split, is well-founded, and confirming those values will be an important next step. Once I have the additional details above, I can better determine whether this is a firmware limitation, a missing configuration dependency, or a kernel-side initialization constraint.
