5326 Discussions
matrix storage manager mirrored wrong disk
TPadi
I have 2 SSD drives that were setup as RAID 1, used for a Windows system partition. For some reason, the mirror was broken and it re-mirrored with the SATA data drive. The second SSD drive is not bad. It just shows that it is not part of the mirror. Is there a way to remove the SATA drive from the mirror and re-add the SSD drive, without losing any data?
Daniel_O_Intel
Check the user guides at http://www.intel.com/support/chipsets/imsm/sb/CS-020670.htm Intel® Rapid Storage Technology (Intel® RST) — User guides , depending on your version of Matrix Storage Manager
