mfsys25 sd broken
FStep1
I have Blade Servers on MFSYS25, and sd card on midplane is broken.
For new sd card, In CMM EBF "sd format" not work,
How make new sd for midplane?
Hello Stefffen,
Support for this http://ark.intel.com/products/48247/Intel-Modular-Server-Chassis-MFSYS25 Intel® Modular Server Chassis MFSYS25 is limited to the website.
If the operational firmware image of the Intel® Modular System MFSYS25 Management Module (CMM) is corrupt, the CMM is unable to boot to Linux*. The CMM contains Emergency Boot Firmware (EBF) that allows the administrator to update the operational image regardless of the state of the current image. The following process uploads a new operational code image to the CMM.
Please make sure you are trying to reformat the SD card and at the "CMM EBF" prompt, type:
set manufacture on sd format exit
If you see the boot process, but cannot get the EBF prompt, note that the serial cable or USB to serial cable must be a fully populated straight-through cable. Specifically, it must allow the host PC to assert the CTS pin on the CMM.
Additionally, you could refer to http://www.intel.com/content/dam/support/us/en/documents/server-products/server-systems/MFSYS25_CMM_Recovery.pdf MFSYS25 Emergency CMM FW Recovery for more information.
Please let us know if you have any further questions.
Caesar B.
FStep1
Thank you for your answer.
I`m insert new sd card.(old broken)
I get serial cable, connect to CMM EBF.
type Set Manufacture On
answer OK
type sd format
answer
Error: Device size (4) or erase size (20000) are incompatible
arguments to command "sd format" must be of the format:
sd format [jffs2/blank]
Need i prepare new sd card?
Hello Stefffen,
The possible scenarios will be the following:
1. SD card not seated properly
2. SC card not installed properly
3. Defective SD card
For 1 and 2 you need to reseat SD card properly and retry
For 3 no other option than replace with a good known SD card
Hope this helps.
Jose H.
Hello Stefffen,
Do you have any updates about this?
Please let us know.
Jose H.
