Intel® Xeon® Processors, Data Center Products including boards, integrated systems, and RAID Storage
s2600cp power fault beep code
JJosh3
Hi, im using an intel s2600cp, with two xeon e5 2620 v1 processors. they are tested working in another system. when i try to power up the system, i get the following error:
1-5-4-2Power faultDC power unexpectedly lost (power good dropout) - Power unit sensors report power unit failure offset.
i have tried using 3 different power supplies, ecc and non ecc ram.
any help would be appreciated
I am following up your case and due to the fact that I haven't heard from you, I am going to proceed and close this threat once for all. If you have any other question let me know and I will be more than happy to assist you.
Emeth O
