ss4200-e turn on remotely
Hi
Is it possibel to turn the power on remotely with the EMC software.
Daniel_O_Intel
No, the SS4200 does not support Wake-On-LAN.
I just tried to wake on lan my ss4200 and it works perfectly...
Nick
Daniel_O_Intel
Nice! It's true that features that aren't supported, may work from time to time. There's just no guarantee of reliability.
with a freeware: fusion WOL (the one I use), but I'm sure even with MC-WOL or other apps will work.
Nick
Thanks it works perfectly.
Wake on lan only works if it just have been shutdown, if it have been turned off for a while it dosen't turn on.
Ok found out that it works with fusion WOL, the problem occurs with MC-WOL, i found depicus where is also is possibel to make a bat file, here it turns on when it has been turned off a while.
You say to create a file bat with mc-wol or with fusion wol?
Nick
You can do it with mc-wol but it dosen' work with ss4200, i use depicus you can get it here: http://www.depicus.com/wake-on-lan/wake-on-lan-cmd.aspxi http://www.depicus.com/wake-on-lan/wake-on-lan-cmd.aspxi then create a bat file with: "wolcmd.exe 7"
