Access member functions inside kernel
student4
I have attached my codes(my_trial_dpcpp.cpp)
When I run this program, it shows an error: implicit capture of this is not allowed in kernel functions.
Is there a way I can access member function in kernel code.
I appreciate your help.
Thank you.
VarshaS_Intel
We have made some changes to your source code in order to run without any errors. Please find the attached source code and the below screenshot to compile and run the code.
Please let us know if you face any issues while running the code.
Thanks & Regards,
Varsha
student4
Thanks a lot for the response.
I have the following issues:
  1. When I uncomment findNext function, I see an error in at 'extern': invalid storage class for a class member
  2. I am trying to use findNext function inside findBest. Is there a way to do so?
Thank you.
VarshaS_Intel
We are working on your issue internally. We will get back to you soon.
Thanks & Regards,
Varsha
Mariya_P_Intel
Hi  @student4,
If you would like to call findNext() function from kernel and findNext() does not use non-static members of class Sample (vectors B and shat), then just add static keyword to fix the compilation:
static complex<float> findNext(sycl::accessor <complex<float>>BAccess)
	complex<float> c = BAccess[0];
	return c;
Mariya
Mariya_P_Intel
Hi @student4,
There was no feedback from you on this thread for a week.
I assume that the above recommendation helped and stop monitoring this thread.
Mariya
