Any way to do array reduction ?
baranovsky
Single variable reduction seems to be possible with sycl::reduction interface.
According to "SYCL 2020 Specification (revision 4)", array reduction will be achieved via reduction interface with std::span, which does not exist in current oneAPI release.
template <typename T, typename Extent, typename BinaryOperation>
__unspecified__ reduction(span<T, Extent> vars, const T& identity, BinaryOperation combiner, const property_list &propList = {});
Is there any way to do array reduction at this point?
Thank you in advance for your help!
NoorjahanSk_Intel
Yes, you are correct array reduction will be achieved via reduction interface with std::span, and is not supported in current oneAPI release. We will discuss with the Developer team and come back with an update soon.
Thanks & Regards,
Noorjahan
NoorjahanSk_Intel
Thanks & Regards,
Noorjahan
cw_intel
DPC++ supports built-in reduction operations, for more information, please refer to this guide https://www.intel.com/content/www/us/en/develop/documentation/oneapi-gpu-optimization-guide/top/kernels/reduction.html
baranovsky
Thank you everyone!
I'm going to implement array reduction by using the built-in reduction operation multiple time.
I will move to the std::span interface, once it is supported!
cw_intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
baranovsky
I found that ruduction of sycl::float2/3/4/8/16 and sycl::double2/3/4/8/16 does the trick for me.
I hope arbitrary-size array reduction will be supported soon!
