886 Discussions
Build error occurs when set TrackerLogDirectory to CICompile
watanabeh
hello.
I have come across an issue where when building a project in which TrackerLogDirectory is explicitly specified in CICompile in vcxprj on the Intel C++ Compiler 2024 platform, the project fails with the following error message.
All Sources must have the same TrackerLogDirectory (xxx).
This error did not occur on Visual Studio 2022 (v143) or the Intel C++ Compiler 2022 platform.
Is there a workaround if I want to explicitly specify TrackerLogDirectory?
thank you.
Alex_Y_Intel
Please provide a small reproducer to demonstrate your issue and exact commands to reproduce.
