In oneAPI 2025.1, the attached test program fails to compile as-is ("icpx -c concept.cpp")
It complains about the include file not being found.
I can get the code to compile by including the absolute path to concepts.hpp, but I shouldn't have to. Also, the above code works fine in oneAPI 2024.1. Is there a trick to using C++20 concepts in 2025.1?
#include <concepts>
double add(double x, double y) {
return x + y;
In fact there's a note on this specific symptom here.
So I guess the guidance for my user is to use gcc-toolset-10 or later when using 2025.0. For 2024 or earlier it appears that you can use RHEL8's default GCC 8.5.
連結已複製
I don't think we have released oneAPI2025.1.
The test case compiled with oneAPI2025.0.1.
$ icpx concept.cpp -c -V
Intel(R) oneAPI DPC++/C++ Compiler for applications running on Intel(R) 64, Version 2025.0.4 Build 20241205
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
$ cat concept.cpp
#include <concepts>
return x + y;
Which gcc version you have on your host?
Thanks for your reply. Our IT people installed it under the name "oneAPI 2025.1" but it appears to actually be 2025.0.1:
$ icpx concepts.cpp -c -V
As for gcc, I'm using the base RHEL 8.1 compilers:
$ gcc --version
gcc (GCC) 8.5.0 20210514 (Red Hat 8.5.0-22)
Copyright (C) 2018 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
One curious observation is that while our 2024.1 folder has these two files named "concepts*":
$MKL_ROOT/include/oneapi/mkl/lapack/concepts.hpp
$DPL_ROOT/include/pstl_offload/concepts
Our 2025.0 folder only has this one:
As far as I can tell, the IT dept selected all of the available options when installing. Could the installer have silently skipped installing the SYCL offload packages for some reason?
icpx will be compatible with Gnu version on your host.
Will you get the same error if you do "g++ concept.cpp -c"?
It doesn't work on g++ either:
$ g++ --version
g++ (GCC) 8.5.0 20210514 (Red Hat 8.5.0-22)
$ g++ -c concepts.cpp
concepts.cpp:1:10: fatal error: concepts: No such file or directory
#include <concepts>
compilation terminated.
Aha! If I enable RHEL8's gcc-toolset-10 or later it works! It does not work with gcc-toolset-9 or the stock gcc 8.5. The oneAPI 2025.0 system requirements say that GCC 7.5 ought to be good enough, but that does not seem to be the case.
gcc-toolset-10 provides the concepts file, but gcc-toolset-9 does not:
$ rpm -ql gcc-toolset-9-libstdc++-devel | grep concepts
$ rpm -ql gcc-toolset-10-libstdc++-devel | grep concepts
/opt/rh/gcc-toolset-10/root/usr/include/c++/10/bits/iterator_concepts.h
/opt/rh/gcc-toolset-10/root/usr/include/c++/10/concepts
I doubt that oneAPI2024.* won't error out with gcc8.5
