C++ Compilier Link Problem with Abaqus
LukePark
Hello.
I got a trouble with linking c++ compiler with Abaqus.
I installed Visual Studio 2019 first,
then installed oneAPI base toolkit and HPC toolkit in order.
And I verified link status,
C++ Compiler stuck in trouble only, Linker and Fortran Compiler are OK.
The message is
"C++ Compiler : Unable to create or determine the version of a C++ compiler on this system.
If a C++ compiler is installed on this system, please load vcvars64.bat file before running Abaqus".
How could I solve this problem?
I've loaded vcvars64.bat file already.
I look forward to your help from those who have experienced the same problem.
LukePark
Hi, Alex.
Thanks for your answering.
I've set up all the contents of the link you sent.
But it's still the same situation.
I suspect a version compatibility issue with each other.
Sravani_K_Intel
If you go to Help > About Microsoft Visual Studio do you see the Visual C++ and Intel C++ Compilers under installed products? If not, you can try repairing your installation to make sure the integration is successful.
