882 Discussions
Compiler error for incorrect include order
FantasticMrFox
I have a program (attached) that has the following header order:
#include <CL/sycl/queue.hpp>
#include <CL/sycl/kernel_handler.hpp>
#include <CL/sycl/handler.hpp>
#include <CL/sycl/specialization_id.hpp>
If i put the header order as follows:
when compiled gives a large error:
In file included from /home/ben/development/hovermap/src/gpu_common/examples/specialisation_constant.cpp:1:
In file included from /home/ben/development/hovermap/src/gpu_common/examples/specialisation_constant.hpp:3:
/opt/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/../include/sycl/CL/sycl/specialization_id.hpp:11:1: error: unknown type name '__SYCL_INLINE_NAMESPACE'
__SYCL_INLINE_NAMESPACE(cl) {
/opt/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/../include/sycl/CL/sycl/specialization_id.hpp:12:1: error: expected expression
namespace sycl {
/opt/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/../include/sycl/CL/sycl/specialization_id.hpp:38:2: error: expected ';' after top level declarator
} // __SYCL_INLINE_NAMESPACE(cl)
In file included from /home/ben/development/hovermap/src/gpu_common/examples/specialisation_constant.hpp:4:
In file included from /opt/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/../include/sycl/CL/sycl/queue.hpp:11:
/opt/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/../include/sycl/CL/sycl/detail/assert_happened.hpp:21:25: error: redefinition of 'cl' as different kind of symbol
/opt/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/../include/sycl/CL/sycl/specialization_id.hpp:11:25: note: previous definition is here
In file included from /opt/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/../include/sycl/CL/sycl/queue.hpp:12:
In file included from /opt/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/../include/sycl/CL/sycl/detail/backend_traits.hpp:11:
In file included from /opt/intel/oneapi/compiler/2022.1.0/linux/bin-llvm/../include/sycl/CL/sycl/backend_types.hpp:13:
In file included from /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/fstream:38:
In file included from /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/istream:38:
In file included from /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/ios:38:
In file included from /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/iosfwd:39:
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/bits/stringfwd.h:79:11: error: no template named 'basic_string'; did you mean '__cxx11::basic_string'?
  typedef basic_string<char>    string;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/bits/stringfwd.h:74:11: note: '__cxx11::basic_string' declared here
    class basic_string;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/bits/stringfwd.h:83:11: error: no template named 'basic_string'; did you mean '__cxx11::basic_string'?
  typedef basic_string<wchar_t> wstring;
    class basic_string;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/bits/stringfwd.h:93:11: error: no template named 'basic_string'; did you mean '__cxx11::basic_string'?
  typedef basic_string<char16_t> u16string;
    class basic_string;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/bits/stringfwd.h:96:11: error: no template named 'basic_string'; did you mean '__cxx11::basic_string'?
  typedef basic_string<char32_t> u32string;
    class basic_string;
In file included from /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/iosfwd:40:
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/bits/postypes.h:98:11: error: unknown type name 'ptrdiff_t'
  typedef ptrdiff_t     streamsize; // Signed integral type
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/iosfwd:147:11: error: no template named 'basic_stringbuf'; did you mean '__cxx11::basic_stringbuf'?
  typedef basic_stringbuf<char>         stringbuf;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/iosfwd:96:11: note: '__cxx11::basic_stringbuf' declared here
    class basic_stringbuf;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/iosfwd:150:11: error: no template named 'basic_istringstream'; did you mean '__cxx11::basic_istringstream'?
  typedef basic_istringstream<char>     istringstream;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/iosfwd:100:11: note: '__cxx11::basic_istringstream' declared here
    class basic_istringstream;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/iosfwd:153:11: error: no template named 'basic_ostringstream'; did you mean '__cxx11::basic_ostringstream'?
  typedef basic_ostringstream<char>     ostringstream;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/iosfwd:104:11: note: '__cxx11::basic_ostringstream' declared here
    class basic_ostringstream;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/iosfwd:156:11: error: no template named 'basic_stringstream'; did you mean '__cxx11::basic_stringstream'?
  typedef basic_stringstream<char>      stringstream;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/iosfwd:108:11: note: '__cxx11::basic_stringstream' declared here
    class basic_stringstream;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/iosfwd:187:11: error: no template named 'basic_stringbuf'; did you mean '__cxx11::basic_stringbuf'?
  typedef basic_stringbuf<wchar_t>      wstringbuf;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/iosfwd:190:11: error: no template named 'basic_istringstream'; did you mean '__cxx11::basic_istringstream'?
  typedef basic_istringstream<wchar_t>  wistringstream;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/iosfwd:193:11: error: no template named 'basic_ostringstream'; did you mean '__cxx11::basic_ostringstream'?
  typedef basic_ostringstream<wchar_t>  wostringstream;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/iosfwd:196:11: error: no template named 'basic_stringstream'; did you mean '__cxx11::basic_stringstream'?
  typedef basic_stringstream<wchar_t>   wstringstream;
In file included from /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/ios:39:
In file included from /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/exception:143:
In file included from /usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/bits/exception_ptr.h:40:
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/new:125:39: error: no type named 'size_t' in namespace 'std'; did you mean simply 'size_t'?
_GLIBCXX_NODISCARD void* operator new(std::size_t) _GLIBCXX_THROW (std::bad_alloc)
/opt/intel/oneapi/compiler/2022.1.0/linux/lib/clang/14.0.0/include/stddef.h:49:23: note: 'size_t' declared here
typedef __SIZE_TYPE__ size_t;
/usr/lib/gcc/x86_64-linux-gnu/9/../../../../include/c++/9/new:127:41: error: no type named 'size_t' in namespace 'std'; did you mean simply 'size_t'?
_GLIBCXX_NODISCARD void* operator new[](std::size_t) _GLIBCXX_THROW (std::bad_alloc)
fatal error: too many errors emitted, stopping now [-ferror-limit=]
20 errors generated.
make[2]: *** [CMakeFiles/using_specialisation_constant.dir/build.make:63: CMakeFiles/using_specialisation_constant.dir/examples/specialisation_constant.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:628: CMakeFiles/using_specialisation_constant.dir/all] Error 2
make: *** [Makefile:141: all] Error 2
 I think this is likely a bug, since header order should not matter.
This is compiled with:
/opt/intel/oneapi/compiler/2022.1.0/linux/bin/dpcpp  -DROSCONSOLE_BACKEND_LOG4CXX -DROS_BUILD_SHARED_LIBS=1 -DROS_PACKAGE_NAME=\"gpu_common\" -I/home/ben/development/hovermap/src/gpu_common/include -I/opt/ros/noetic/include -I/opt/ros/noetic/share/xmlrpcpp/cmake/../../../include/xmlrpcpp  -fclang-abi-compat=7 -fsycl --gcc-toolchain=/usr -sycl-std=2020 -fp-model=precise -Wall -Werror -fsycl  -O2 -g -DNDEBUG   -std=gnu++17 gpu_common/examples/specialisation_constant.cpp gpu_common/examples/using_specialisation_constant.cpp
ShivaniK_Intel
Thanks for posting in the Intel forums.
We are able to reproduce the issue on our end. We are working on it and will get back to you.
Thanks & Regards
Shivani
ShivaniK_Intel
The reason is that #include <CL/sycl.hpp> must be included in using_specialisation_constant.cpp and specialisation_constant.hpp.
Once it is included, you don't need the list of SYCL headers anymore.
Please let us know if you further face any issues.
Thanks & Regards
Shivani
FantasticMrFox
This is not a satisfactory solution. You are breaking the cpp core guidelines. Header files should be self contained.
I have linked the guideline. By including all of sycl, not just the required headers, you are making our code take longer to compile as well. This is not particularly nice.
With this solution you are also forcing us to break the core guideline: Avoid dependencies on implicity included header files.
We don't need this fixed now, but it is still a bug.
ShivaniK_Intel
We are working on it and will get back to you .
Thanks & Regards
Shivani
ShivaniK_Intel
Thanks for your patience.
Our development team is working on it and will let you know once it is fixed.
Thanks & Regards
Shivani
