DPC++ toolchain
cristianvasileachim
I am trying to set up my one toolchain in my own folder on a cluster.  I have no root access.
I was able to compile the intel llvm wiht nvidia gpu support on top on cuda toolkit 11.5.0. I am able to run sycl codes using the gpu selector , but when I use th ecou selector it does not find any device.
How do I compile hte intel llvm to have support for both nvidia gpus and cpus without root access?
Cristian
Edit:
Trying to compile with cpu fsycl-targets I get the error below:
$DPCPP_HOME/llvm/build/bin/clang++ -std=c++17 -O3 -fsycl -fsycl-targets=nvptx64-nvidia-cuda,cpu --cuda-path=$CUDA_HOME -L$GCC_INSTALL_RO
OT/lib64 enumerate_gpu.cpp
clang++: error: SYCL target is invalid: 'cpu'
clang++: /scratch/project_2008874/sycl_workspace/llvm/clang/lib/Driver/Driver.cpp:6350: virtual bool {anonymous}::OffloadingActionBuilder::SYCLActionBuilder::initialize(): Assertion `TCIt != ToolChains.end() && "Toolchain was not created for this platform"' failed.
PLEASE submit a bug report to https://github.com/intel/llvm/issues and include the crash backtrace, preprocessed source, and associated run script.
Stack dump:
0.      Program arguments: /scratch/project_2008874/sycl_workspace/llvm/build/bin/clang++ -std=c++17 -O3 -fsycl -fsycl-targets=nvptx64-nvidia-cuda,cpu --cuda-path=/appl/spack/v017/install-tree/gcc-11.2.0/cuda-11.5.0-mg4ztb -L/appl/spack/v017/install-tree/gcc-8.5.0/gcc-11.2.0-zshp2k/lib64 enumerate_gpu.cpp
1.      Compilation construction
2.      Building compilation actions
Stack dump without symbol names (ensure you have llvm-symbolizer in your PATH or set the environment var `LLVM_SYMBOLIZER_PATH` to point to it):
0  clang++         0x0000000001f513bb llvm::sys::PrintStackTrace(llvm::raw_ostream&, int) + 219
1  clang++         0x0000000001f4e914
2  libpthread.so.0 0x00007f3dc0a33ce0
3  libc.so.6       0x00007f3dbf61ba9f gsignal + 271
4  libc.so.6       0x00007f3dbf5eee05 abort + 295
5  libc.so.6       0x00007f3dbf5eecd9
6  libc.so.6       0x00007f3dbf6143f6
7  clang++         0x0000000002804eba
8  clang++         0x00000000027cd515
9  clang++         0x0000000002812a95 clang::driver::Driver::BuildActions(clang::driver::Compilation&, llvm::opt::DerivedArgList&, llvm::SmallVector<std::pair<clang::driver::types::ID, llvm::opt::Arg const*>, 16u> const&, llvm::SmallVector<clang::driver::Action*, 3u>&) const + 11205
10 clang++         0x000000000281786f clang::driver::Driver::BuildCompilation(llvm::ArrayRef<char const*>) + 5135
11 clang++         0x0000000000b3bdb5 clang_main(int, char**, llvm::ToolContext const&) + 4293
12 clang++         0x0000000000a85201 main + 33
13 libc.so.6       0x00007f3dbf607cf3 __libc_start_main + 243
14 clang++         0x0000000000b3698e _start + 46
Aborted
Later edit:
Running the sycl-ls I get this:
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$DPCPP_HOME/llvm/build/lib srun  --time=00:15:00 --partition=gputest --account=project_2001498 --nodes=1 --ntasks-per-node=1  --cpus-per-task=1 --gres=gpu:a100:4  $DPCPP_HOME/llvm/build/bin/sycl-ls
[ext_oneapi_cuda:gpu:0] NVIDIA CUDA BACKEND, NVIDIA A100-SXM4-40GB 8.0 [CUDA 12.0]
[ext_oneapi_cuda:gpu:1] NVIDIA CUDA BACKEND, NVIDIA A100-SXM4-40GB 8.0 [CUDA 12.0]
[ext_oneapi_cuda:gpu:2] NVIDIA CUDA BACKEND, NVIDIA A100-SXM4-40GB 8.0 [CUDA 12.0]
[ext_oneapi_cuda:gpu:3] NVIDIA CUDA BACKEND, NVIDIA A100-SXM4-40GB 8.0 [CUDA 12.0]
No cpu are found.
