843 Discussions
DPL functions cannot be correctly linked, is there any other lib required?
shenuo
Here is my code:
#include <CL/sycl.hpp>
#include <vector>
#include <iostream>
#include <oneapi/dpl/algorithm>
#include <algorithm>
using namespace sycl;
int main(int argc, char* argv[]) {
std::vector<int> a;
a.resize(100);
oneapi::dpl::fill(oneapi::dpl::execution::par_unseq,a.begin(),a.end(),3);
return 0;
error LNK2019: unresolved external symbol "void __cdecl oneapi::dpl::fill<class oneapi::dpl::execution::v1::parallel_unsequenced_policy const &,class std::_Vector_iterator<class std::_Vector_val<struct std::_Simple_types<int> > >,int>(class oneapi::dpl::execution::v1::parallel_unsequenced_policy const &,class std::_Vector_iterator<class std::_Vector_val<struct std::_Simple_types<int> > >,class std::_Vector_iterator<class std::_Vector_val<struct std::_Simple_types<int> > >,int const &)" (??$fill@AEBVparallel_unsequenced_policy@v1@execution@dpl@oneapi@@V?$_Vector_iterator@V?$_Vector_val@U?$_Simple_types@H@std@@@std@@@std@@H@dpl@oneapi@@YAXAEBVparallel_unsequenced_policy@v1@execution@01@V?$_Vector_iterator@V?$_Vector_val@U?$_Simple_types@H@std@@@std@@@std@@1AEBH@Z) referenced in function main
my programing environment :
VS2017
oneAPI DPC++ Compiler  (2021.3.0)
windows 10
shenuo
problem solved. must contain the <dpl/excution>header, Besides, the tbb.lib also requires to be linked. I didn't found this point mentioned in the tutorial.  o_o
shenuo
ArpitaP_Intel
Glad to know your issue is resolved. It would be a great help if you let us know the tutorial document you are referring.
Thanks!
shenuo
ArpitaP_Intel
You can get the detailed steps in the below URL
https://software.intel.com/content/www/us/en/develop/documentation/oneapi-dpcpp-library-guide/top/parallel-stl-overview/parallel-stl-usage.html
As your issue is resolved, we are going ahead and closing this thread. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks!
