Disable GPU hung limit
peizhao
Hi, I am attempting to perform benchmarking on the Intel Data Center GPU MAX 1100 using SYCL. However, I've noticed that the program often hangs due to a driver restriction, as detailed in the following link. Is there a way to disable this restriction?
VaishnaviV_Intel
Thanks for posting on Intel communities.
Could you please provide us with the following information?
  1. Are you trying to execute your code on Intel devcloud?
  2. Please share the sample reproducer along with the steps you have followed.
  3. Regarding your operating system, if you are using a Windows system, please provide a screenshot of the Task Manager, specifically navigating to Performance -> GPU. If you are using Linux system, execute the clinfo command and share the output with us.
Please follow the steps mentioned in the below link,
https://www.intel.com/content/www/us/en/docs/oneapi/installation-guide-linux/2023-2/gpu-disable-hangcheck.html
Thanks & Regards,
Vankudothu Vaishnavi.
VaishnaviV_Intel
Thanks & Regards,
VaishnaviV_Intel
We have not heard back from you. Could you please provide us with the details we have asked for?
Thanks & Regards,
VaishnaviV_Intel
We haven't heard back from you. If you have any issues, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
