Dump assembly
zjin-lcf
Can you please list the steps of producing  assembly codes for a SYCL kernel ? The compiler is DPC++ and the selector is either cpu_selector or gpu_selector.  Thanks.
DitiD_Intel
You can use the /Fa or -Fa on Windows and Linux respectively to generate the assembly code while compiling with dpcpp compiler.
Please refer to the link mentioned below for more information.
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-dpcpp-cpp-compiler-dev-guide-and-reference/top/compiler-reference/compiler-options/compiler-option-details/output-debug-and-precompiled-header-pch-options/fa.html#fa
If you still face any issues in generating assembly code, then please do share the environment details and a sample reproducer so that we can try it from our end.
Thanks & Regards,
Ditipriya.
DitiD_Intel
Thanks & Regards,
Ditipriya.
DitiD_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
Ditipriya.
