Enabling FMAs and disabling vectorisation
MikeSmith1
I am trying to obtain a version of the code with FMAs enabled and *all* vectorisations disabled. In essence, something that I would obtain with GCC using -mfma and -fno-tree-vectorize.
(I am using a Windows machine).
I notice that /Qfma (-fma) exists to enable FMAs but it must be used alongside a flag specifying the architecture. But that in turn enables vectorisations. I tried switching them off with /Qvec- (-no-vec) but vectorised assembly instructions still get produced. I also tried using /Qno-simd to switch them off, but I get:
icx: command line warning #10430: Unsupported command line options encountered
These options as listed are not supported.
For more information, use '/Qnextgen-diag'.
option list:
/Qsimd-
What is the way to go here? Thank you.
NoorjahanSk_Intel
Could you please provide us with a sample reproducer and steps you have followed so that we can try it from our end?
Also please let us know the compiler version being used along with expected and obtained results.
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
I have not heard back from you, so I will close this inquiry now. If you need further assistance, please post a new question.
Thanks & Regards,
Noorjahan.
